Anti-termite Work
This is a most important work in any construction project done to keep the concrete health for its lifetime.
Checklist of Anti-termite Work consist of following checkpoints in it;
Please find attached sample checklist format for recording the results of activity.
- Anti-termite chemicals of approved quality and brand: SPECIFY MATERIAL( )
- Methodology and proportions of mix as approved (manufacturers specification)
- Safety precautions followed during treatment
- Proper penetration of chemicals into the surface
- Measurements noted
