Work Checklist - Back Filling Work
Back Filling Work
After creation of foundation of structure we generally do back fill the excavated portion. This checklist helps you in doing it in correct way.
Checklist of Back Filling Work consist of following checkpoints in it;
  • Backfilling material approved
  • Material free from impurities
  • Bottom levels taken/noted
  • Rock pieces not greater than 150mm
  • Filling layers not greater than 150mm (or as directed by incharge)
  • Watering of layers filled
  • Proper compaction by approved method /machinery.
  • Slopes maintained if required
  • Top levels taken
  • Field density tested and results approved by incharge
Please find attached checklist for back filling work.
  • C4M Back Filling Works.docx
