Door Shutter Works
Door shutters acts as barrier to ensure privacy, safety and security of peoples. So during door shutter fixing work we should check all points by doing tick mark in checklist.
Checklist of Door Shutter Works consist of following checkpoints in it;
procedures to be followed before fixing
procedures to be followed during fixing
Checklist for Door shutter fixing work is attached herewith.
- Section, size and type of Door shutter as per architectural drawing
- Stacking of door shutters done as per specification on site
- Door shutter free from bend, warpage ,twist etc.
- Beading patti fixed on all four sides of the shutter
- Colour and thickness of veneer checked before fixing.(if any)
- Door shutter fixed in line, level and plumb .
- Min . 3 hinges used for shutters up to 900mm and 4 hinges used for shutters more than 900mm.
- All screws are screwed and not hammered
- Uniform gap kept between door frame and door shutter.
- Fittings, Fixtures of shutters fixed as per architecture drawing and using approved material .
- Moulding patti fixed on the junction of door frame and wall as specified in the drawing.
- Polishing/painting/melamine done as per specification.
- Smooth operation of door shutter ,fittings ,fixtures checked.
