External Drainage Works
Drainage is important function and should happen without any obstruction, if this stop functioning, a customers / owners of house get dis satisfied with the quality of work done and the company looses potential buyers due to this, as it stands as negative advertisement for company. All points must be check during execution of external drainage works.
Checklist of External Drainage Works consist of following checkpoints in it;
Procedures to be followed before external drainage
Procedures to be followed during external drainage
Procedures to be followed after external drainage
Sample checklist for external drainage work is attached herewith.
- Approved plumbing drawings available on site
- Marking of pipelines on outer walls done
- Positions of outlet pipes marked and holes drilled as specified
- Sufficient gap kept between wall surface and pipes
- All vertical lines are in plumb
- Invert levels of Inspection Chambers checked
- BB Masonry Inspection Chambers plastered from inside and outside
- Jointing of C. I./ PVC / SWG /SWR/ RCC pipes done as specified
- Slope of the entire drainage line as specified
- Anti-siphon pipe directly connected to water closets
- Branch lines joining main sewer line as specified
- Rain water pipes provided with 45 degree shoe at bottom
- All traps / Inspection chambers cleaned as specified
- Cleaning carried out from top floor to bottom floor
- Gravity Pressure Testing carried out as specified
- Leakages, if any, are corrected after Pressure Test as specified
- Masonry holes rendered with non-shrink grout
- Sewer / Anti-siphon pipes provided with vent cowls with mosquito nets
