Work Checklist - External Plaster Works
To protect the concrete and wall surface and make a smooth finish straight line external faces we do plaster on it.
To have a good defect free plaster, one must check the points listed in checklist during plastering activity.
Checklist for External Plaster Works consist of following checkpoints in it;
Procedures to be followed before plastering
  • Masonry surface cleaned as specified
  • Sequence of plastering decided in advance
  • Scaffolding material checked and erected as specified
  • Beam bulges chipped off
  • Gaps in brickwork filled from outside 2 days in advance as specified
  • Wetting of brick surface done as specified.
  • Level pads taken / line doris stretched as specified
  • Chicken mesh / fiber mesh fixed at BBM and concrete joints as specified
  • Coping to parapet top complete
  • Plumbing pipe holes made and finished as specified.
Procedures to be followed during plastering
  • Mortar proportion and dosage of admixture (if any) as specified.( )
  • Mortar used within 90 minutes of preparation
  • Water-proofing compound added as specified
  • Thickness of first coat kept maximum 15mm
  • Thickness of second coat kept maximum 8 mm
  • Time gap / curing / application of bonding agent between two coats as specified
  • Max gap between 2 coats kept 5 days or bonding agent used
  • Pani patti / groove provided as specified
  • Chhajja top plaster (rounded) merged inside with external plaster
  • Finishing of plaster done as specified
  • Plaster taken over parapet wall inside terrace without joint
  • Parapet top given inside slope as specified
  • Plaster joints kept at center of beams
Procedures to be followed after plastering
  • Cleaning of frames/other surfaces done as specified
  • Date of plastering marked for monitoring curing
  • Curing carried out for 7 days as specified.
Checklist for external plaster work is attached herewith.
  • C4M External Plaster Works.docx
Reactions: Ramesh2019
