Flyash Brick Masonry Works
For doing a partition wall, we use flyash bricks.
Checklist of Flyash Brick Masonry Works, consist of following checkpoints in it;
Checklist for doing flyash brick masonry work is attached herewith.
- Approved architectural drawings available on site
- RCC slab surface is cleaned properly
- Line out checked as per drawing (first layer )
- Fish wire pulled through conduits and beam bottom cleared
- RCC column/wall surface roughened /mortar dash applied
- Wetting of bricks done prior to use
- Mortar proportion as specified ( )
- M.S. trays used for mortar mixing
- Mortar used within 45 minutes after mixing
- Independent scaffolding system done for masonry
- Provision for door openings/ windows openings /hold fasts/architectural feature checked
- For 150mm thick Wall R.C.C. band provided.
- Staggering of brick joints ensured
- Proper bond/ anchorage with cross wall checked
- Masonry joints kept not more than 10mm
- Racking of joints done
- Rich mortar metal packing provided for RCC and masonry joint
- Construction date marked on wall
- Curing of masonry ensured minimum for 7 days.
