Work Checklist - Internal Cement Sand Plaster
The wall surface is plastered with cement sand mortar to achieve a smooth finish on wall surface.
Checklist of Internal Cement Sand Plaster, consist of following checkpoints in it;
Procedures to be followed before internal plaster
  • Surface cleaned of algae, efflorescence, oily patches etc.
  • 7 days gap between masonry construction and plaster application
  • Masonry walls well-watered before start of internal plastering, as specified
  • Door / Window openings checked as per drawing (necessary corrections done if required)
  • Level pads (min 2"x 2") made on walls
  • Level pads found correct for plumb and right angle for walls
  • Chicken mesh / fiber mesh fixed at BBM and concrete joints as specified
  • Base frame fixed (if specified) before plaster
  • Sufficient lighting arrangement provided in dark areas
Procedures to be followed during internal plaster
  • Mortar mixed as specified ( )
  • Mortar used within 90 minutes of preparation
  • Thickness of one coat not more than 15mm-18mm
  • Electrical switch boxes in line with finished plaster level
  • Plaster thickness of more than 18mm done in two coats
  • Plaster cut above skirting level
  • Plaster done /cut above FFL of toilet as specified
  • Back coat roughened where wall tiles are to be fixed
  • Plumb, right angle, line, level of finished plaster found ok.
Procedures to be followed after internal plaster
  • Date of plastering marked to monitoring curing
  • All surfaces cleaned off mortar
  • Curing of plastered surface ensured for 7 days
The work checklist for internal cement sand plaster is attached herewith.
  • C4M Internal Cement Sand Plaster Works.docx
Reactions: Mounesh
