Work Checklist - Internal Painting Works
Paint is a final finish on wall and it should be done with care and should be checked during various stages as per checklist.
Checklist of Internal Painting Works consist of following checkpoints in it;
Procedures to be followed before internal painting
  • All civil and electrical works complete
  • Main door provided with locking arrangement
  • Wall surface dry checked
  • Alkalinity of wall surface checked
  • Dirt and dust particles removed off from wall surface by papering
  • Electrical boards/switches/windows/decorative pieces /covered properly with masking tape
  • Material - Primer, paint, putty, to be used of approved brand /color / shade/ texture.
  • Manufacturers literature available on site
  • Approved shade card with final shades marked on them available on site
  • Brush /roller /water paper/ emery paper/sand paper to be used of approved brand and no.
  • Scaffold to be used with proper protection for legs to avoid scratches on flooring
Procedures to be followed during internal painting
  • Primer coat applied ( 1st coat) as specified
  • Putty applied over primer (to eliminate the undulations in wall ) as specified
  • Papering of putty done
  • Primer coat applied ( 2nd coat ) as specified
  • Paint applied as specified ( minimum 2 coats)
  • Use of roller to give required texture as specified for application of paint
Procedures to be followed after internal painting
  • Finished surface texture satisfactory
  • Cleaning of flooring / window panes /electrical fixtures / fittings / skirting etc. done as specified
Work checklist for internal painting is attached herewith.
  • C4M Internal Painting Works.docx
