Slab and Beam Shuttering Works
This checklist helps in doing checking of slab and beam shuttering work.
- Checklist for Slab and Beam Shuttering Works consist of following checkpoints;
- Approved formwork drawing available on site
- Cleaning, oiling for shuttering done
- Beam bottom and slab bottom level checked
- Beam width and beam depths as per drawing
- Plumb of sides of beam checked and found satisfactory
- Shikhanja spacing as approved
- Column topi checked and found satisfactory
- Vertical stoppers provided as approved
- Sides of beam around toilet sunk provided with sleeves as per drawing
- Spans after opening have min 450mm overlap and have min 2 bolts
- Spans are supported by steel props at ends and not in-between
- Prop size, spacing and condition as per approved drawing.
- Bracing as per approved drawing.
- Props are resting on firm surface as per guidelines
- Top level of Concrete – Marked
- Tie rod or alternative support (if Required).
- Opening for electrical outlets if any as per drawing & specification
