Work Checklist - Waste soil, vent pipe fixing
This checklist provides points to ensure during execution of waste soil and vent pipe fixing.
Checklist of Waste soil, vent pipe fixing consist of following checkpoints in it;
  • Checklist of Masonry
  • Material: Make / class / thickness / length / dia as specified, regular shape of socket and spigot end, no visible crack/holes and all in sufficient quantity
  • Pipe tested for water leakage (one end plugged and water filled in vertical pipe, to be tested for selected at random pipes)
  • Alignment and location of fittings
  • Slope of Drainage pipe, verticality of vent pipe
  • Location of floor / gully traps, location of usage / provision for future points / location of inlet points / type of fixture
  • Supports for pipe fittings (fixtures / clamps / packing), space available for sanitary fixtures & temporary plugging - clamps to be fixed in concrete - all packing to be done with approved non- shrinkage grout
  • Fixing and jointing as specified
  • Pipe protection by all round concrete (where required)
  • Smoke test (one end plugged, smoke injected, no leakage observed and section passes) for all sections (if required)
  • All traps covered with small pieces of gunny bag and plaster of paris, cowl fixed on vent pipe
Sample checklist format is attached in this post.
  • C4M Waste Soil_ Vent Pipe Fixing Works.docx
