The buckling load in a steel column is -
(a) Directly proportional to the slenderness ratio
(b) Inversely proportional to the slenderness ratio
(c) Related to the length
(d) Non-linear by related to the slenderness ratio.
The correct Answer Is
Reactions: Sumit Civil
(b) Inversely proportional to the slenderness ratio.
As we know
A short column under the action of an axial load will fail by direct compression before it buckles, but a long column loaded in the same manner will fail by springing suddenly outward laterally (buckling) in a bending mode. The buckling mode of deflection is considered a failure mode, and it generally occurs before the axial compression stresses (direct compression) can cause failure of the material by yielding or fracture of that compression member. However, intermediate-length columns will fail by a combination of direct compressive stress and bending.
(c) Related to the leoptioon c
ngth
