Check list for Brickwork
Check list for Brickwork consist of following points;
enclosed herewith the detailed checklist for brickwork
- Check for clean area
- Check whether the customer
- choice is in place
- Check for hacking at the column edge, floor & beam soffit
- Check for brick test report
- Check the layout in plumb with the beams
- Check the cement used :
- Brand of the Cement
- Lot no. of the Cement
- Check for mortar making platform
- Check for mortar mix (cement : sand) for diff. thickness of wall
- Check for cube taken of the bed mortar
- Check door, window, AC cutout openings
- Check the R.C.C. band plumb of A.C. cutout
- Check the holes left at the brickwall above A.C. band
- Check for chicken wire mesh at 90mm thick & 75mm thick wall
- Check for pointing, jointing and level of the Brickwall
- Check for soffit of loft, lintel & 900mm outside peripheral beam at same level
- Check for plumb of brickwall
- Check for bed mortar thickness
- Check dates are written in the walls
- Check for PCC at window sills
- Check for RCC band shuttering
- Check for RCC band R.I.
- Check for RCC Jali, Golu & Precast Lintels
- Check bricks used in diff. walls
- Check for vertical joints & bonding of brickwork at rt. Angles
- Check the different bricks used at the junction of external and partition wall
- Check for brick used for break joints at every alternate layers
- Check for top layer of brick work touching beam & slab soffit is a full brick
- Check brickwork done above and below window of A type and C type living room (240 mm wall)
- Check the lintel projections till the end to support the above point in A and C type flat
- Check the toilet lintel rods are hooked properly from the beam in both A & C type Master toilet
- Check for fabricated elements in balcony's and at AC cutouts
- Check for efflorescence while doing the curing of Brickwall
- Check the snag report is ready & attended simultaneously
- Check the waste management plan is followed
- Check for floor cleaning from all loose materials
