Checklist for Plumbing Works
Checklist of plumbing work consist of following points;
- Check the wall has been plastered with waterproofing compound
- Check the shaft wall has been cleared from all loose materials
- Check safety precautions are taken care of at the top & bottom in span of work
- Check the pipes for the approved make
- Check for quality and size of the pipes as per specs
- Check for quality of supports, fixtures, sealants, bolts, nuts, thread pads, collars etc
- Check routing to coordinate with other services, if any
- Check for compatibilty of fastners, sealant and sleeves
- Check for waterproofing joints near the core cuts
- Check for waterproofing testing around the core cuts
- Check for all joints for air tightness by pressure testing and smoke test
- Check all terminal connection in relation to flow diagram
- Check for wall tippas before starting water lines in toilets and kitchen
- Check the position of diverters, pillar cocks, bibcocks,
- consist stop cock and angular stop cocks position with respect to tiles
- Check the level of the rain water pipes in balconys with tiles.
- Check the level of the rain water pipes in slope with the terrace.
- Check for all operational valves, meters etc for effective controlling & operation
- Check all the pipes are placed before closing it from inside toilet and kitchen
- Check the ducts are cleaned & pipes are painted before closing Brickwork
- Check the area is cleaned for the succeeding contractor
