Coefficient of Measurements for Painting on various surfaces
Partly paneled and glazed doors : 0.80 times the door or window area.
Collapsible gates : 1.50
Corrugated sheeted steel doors : 1.25
Rolling shutters : 1.10
Expanded metal hard drawn steel : 1.00
Open palsied fencing and gates, brace, rails : 1.00
Corrugated iron sheeting : 1.14
A.C corrugated sheeting : 1.20
Semi corrugated sheeting : 1.10
Wire gauged shutters : 1.00
Paneled framed and braced doors, windows : 1.30
Ledged and battened doors and windows : 1.30
Flush doors : 1.20
Partly paneled doors : 1.00
Fully glazed doors : 0.80
Fully louvered : 1.80
Trellis work : 2.00
Curved or enriched : 2.00
Weather boarding : 1.20
Wooded single roofing : 1.10
Boarding with cover tilets and match boarding : 1.05
Tile and slate battering : 0.80
Plain sheeted steel : 1.10
Fully glazed steel : 0.50
co efficient means a method of measurement. for instant flat surface of 10 sqm is measurable as 10 sqm. in case of corrugated how the measurement is to be done. in case of a grill how the measurement is to be done. hence the coefficient method is derived by c.p.w.d and is authorities, simply i posted the same. in a major projet tenders the coefficient is always mentioned.
So total area ×Co efficient =area of paints.
is it crt?
co efficient means a method of measurement. for instant flat surface of 10 sqm is measurable as 10 sqm. in case of corrugated how the measurement is to be done. in case of a grill how the measurement is to be done. hence the coefficient method is derived by c.p.w.d and is authorities, simply i posted the same. in a major projet tenders the coefficient is always mentioned.[/Q
Reactions: VIDHYA SAGAR
Thank you Sir for very valuable knowledge data shared.
I require your assistance. can you share coefficients for Wood Polish such as French Polish, Melamine Polish etc.
I specifically have query about the edge polishing done (one side is less 12"), wherein contractors charge on RFT/RMT. My specifics are
1. Cushioned Chair
2. Glass table with wooden edges and legs,
3 Bed side edges, cornices.
Please assist.
Regards
