Concrete Mix Design for M20 grade
Concrete Mix Design for M20 grade of concrete
M20 is commonly used most popular grade of concrete for RCC works.
Concrete mix Design for M20 Grade concrete with fly ash is as follows;
OPC Cement 53 Grade – 259 Kg
Fly ash – 61 Kg
Water Cement ratio (w/c) – 0.5
Free Water – 160 liters
20mm Metal / Aggregates – 519 Kg
10mm Metal / Aggregates – 495 Kg
Crush Sand – 1027 Kg
Admixture Dosage – 0.6%
Admixture – 1.92 Kg
Density of Concrete – 2523 Kg/cum
  • M20 with Fly ash.xlsx
Concrete mix Design for M20 Grade concrete with PPC Cement is as follows;
PPC Cement 53 Grade – 320 Kg
20mm Metal / Aggregates – 531 Kg
10mm Metal / Aggregates – 489 Kg
Crush Sand – 1049 Kg
Admixture – 1.92 Kg
Density of Concrete – 2550 Kg/cum
  • M20 PPC.xlsx
Concrete Mix Design for M20 Grade with GGBS is as follows;
OPC Cement 53 Grade – 230 Kg
GGBS – 90 Kg
Water Cement ratio (w/c) – 0.47
Free Water – 150 liters
20mm Metal / Aggregates – 787 Kg
10mm Metal / Aggregates – 350 Kg
Crush Sand – 969 Kg
Admixture – 1.92 Kg
Density of Concrete – 2577 Kg/cum
  • M20 with GGBS.xlsx
Reactions: Pankaj Sharma
Pankaj Sharma
GGBS – 90 Kg
Crush Sand – 969 Kg
Admixture – 1.92 Kg
Thanks Sir for sharing these valuable knowledge.
The name of the Admixture
You can use any admixture brand available in your area.
dosage of admixture are depends on the performance requirement and retention time.
If you wish to retain the workability of concrete for longer time, the dosage and quality of admixture get varies.
The admixture use in above mix design are normal range SNF base super plastisizers.
Khan Shaf
Apprentice
Thank you sir
