Concrete Mix Design for M20 grade
Concrete Mix Design for M20 grade of concrete
M20 is commonly used most popular grade of concrete for RCC works.
Concrete mix Design for M20 Grade concrete with fly ash is as follows;
OPC Cement 53 Grade – 259 Kg
Fly ash – 61 Kg
Water Cement ratio (w/c) – 0.5
Free Water – 160 liters
20mm Metal / Aggregates – 519 Kg
10mm Metal / Aggregates – 495 Kg
Crush Sand – 1027 Kg
Admixture Dosage – 0.6%
Admixture – 1.92 Kg
Density of Concrete – 2523 Kg/cum
The complete mix design file is attached herewith.
You can modify the mix design by changing the specific gravities of materials which will make it relevant as per the material available at your place.
Changing the specific gravity will change the weight of material in mix design which is automatically calculated.
Do not use this mixes directly without doing prior trials of it, the data provided is for educational and better understanding of mixes.
After doing trial, if any issue observed, you can do adjustment by adjusting the % of each size of aggregate to achieve the required properties of fresh concrete.
Do ensure total of all aggregate percentage in mix should some to 100%
In general, for direct placement concrete
Ration of fine aggregates to coarse aggregates kept between 35:75 to 40:60
In case of pump concrete the fine content is kept above 45%
You can adjust the percentages of fines and coarse by looking at the concrete produced during trial.
Admixtures plays an important role in properties of fresh concrete specially in workability and retention.
Do select admixture correctly to ensure no failure during actual use of concrete.
All can reply to this thread with there mix design of same grade, this will help other to understand designing in more better way and can do a cost optimization.
Concrete mix Design for M20 Grade concrete with PPC Cement is as follows;
PPC Cement 53 Grade – 320 Kg
20mm Metal / Aggregates – 531 Kg
10mm Metal / Aggregates – 489 Kg
Crush Sand – 1049 Kg
Admixture – 1.92 Kg
Density of Concrete – 2550 Kg/cum
Concrete Mix Design for M20 Grade with GGBS is as follows;
OPC Cement 53 Grade – 230 Kg
GGBS – 90 Kg
Water Cement ratio (w/c) – 0.47
Free Water – 150 liters
20mm Metal / Aggregates – 787 Kg
10mm Metal / Aggregates – 350 Kg
Crush Sand – 969 Kg
Admixture – 1.92 Kg
Density of Concrete – 2577 Kg/cum
Reactions: Pankaj Sharma
GGBS – 90 Kg
Crush Sand – 969 Kg
Admixture – 1.92 Kg
Thanks Sir for sharing these valuable knowledge.
The name of the Admixture
You can use any admixture brand available in your area.
dosage of admixture are depends on the performance requirement and retention time.
If you wish to retain the workability of concrete for longer time, the dosage and quality of admixture get varies.
The admixture use in above mix design are normal range SNF base super plastisizers.
Thank you sir
