Concrete mix Design for M40 Grade for Mivan Formwork
Concrete mix Design for M40 Grade Concrete for Mivan Formwork with PPC Cement
PPC Cement 53 Grade – 480 Kg
Water Cement ratio (w/c) – 0.32
Free Water – 153 liters
20mm Metal / Aggregates – 486 Kg
10mm Metal / Aggregates – 450 Kg
Crush Sand – 999 Kg
Admixture Dosage – 1 %
Admixture – 4.8 Kg
Density of Concrete – 2574 Kg/cum
  • M40 PPC For Mivan.xlsx
