Concrete mix Design for M50 Grade for Mivan Formwork
Concrete mix Design for M50 Grade concrete with PPC Cement for Mivan Formwork is as follows;
PPC Cement 53 Grade – 560 Kg
Water Cement ratio (w/c) – 0.30
Free Water – 168 liters
20mm Metal / Aggregates – 467 Kg
10mm Metal / Aggregates – 471 Kg
Crush Sand – 883 Kg
Admixture Dosage – 1 %
Admixture – 5.6 Kg
Density of Concrete – 2554 Kg/cum
  • M50 PPC For Mivan.xlsx
