Concrete mix Design for M60 Grade concrete, a Triple Blend with Fly ash and Micro silica is as follows;
OPC Cement 53 Grade – 450 Kg
Fly ash – 80 Kg
Micro silica – 40 Kg
Water Cement ratio (w/c) – 0.24
Free Water – 137 liters
20mm Metal / Aggregates – 587 Kg
10mm Metal / Aggregates – 471 Kg
Crush Sand – 637 Kg
River Sand – 208 Kg
Admixture Dosage – 0.8 %
Admixture – 4.56 Kg
Density of Concrete – 2613 Kg/cum
Fly ash – 80 Kg
Crush Sand – 637 Kg
River Sand – 208 Kg
Admixture – 4.56 Kg
