Concrete Mix Design for M60 grade - A triple blend mix
Concrete mix Design for M60 Grade concrete, a Triple Blend with Fly ash and Micro silica is as follows;
OPC Cement 53 Grade – 450 Kg
Fly ash – 80 Kg
Micro silica – 40 Kg
Water Cement ratio (w/c) – 0.24
Free Water – 137 liters
20mm Metal / Aggregates – 587 Kg
10mm Metal / Aggregates – 471 Kg
Crush Sand – 637 Kg
River Sand – 208 Kg
Admixture Dosage – 0.8 %
Admixture – 4.56 Kg
Density of Concrete – 2613 Kg/cum
The complete mix design file is attached herewith.
You can modify the mix design by changing the specific gravities of materials which will make it relevant as per the material available at your place.
Changing the specific gravity will change the weight of material in mix design which is automatically calculated.
Do not use this mixes directly without doing prior trials of it, the data provided is for educational and better understanding of mixes.
After doing trial, if any issue observed, you can do adjustment by adjusting the % of each size of aggregate to achieve the required properties of fresh concrete.
Do ensure total of all aggregate percentage in mix should some to 100%
In general, for direct placement concrete
Ration of fine aggregates to coarse aggregates kept between 35:75 to 40:60
In case of pump concrete the fine content is kept above 45%
You can adjust the percentages of fines and coarse by looking at the concrete produced during trial.
Admixtures plays an important role in properties of fresh concrete specially in workability and retention.
Do select admixture correctly to ensure no failure during actual use of concrete.
All can reply to this thread with there mix design of same grade, this will help other to understand designing in more better way and can do a cost optimization.
  • M60 with Fly ash micro silica.xlsx
uday0207
Dear Sir,
Pls share following details:-
(a) name and brand of Admixture used.
(b) Workability of fresh concrete mix.
(c) Average comp strength of final trial mix (used in the work) at 28 days.
Regards.
U S Prasad
Director (Planning)
MES
PUNE
