detailed presentation on the function of doors and windows
Elite Member
Sep 21, 2017
265
370
India
#1
•The function of a door is to give access to building and to different parts of the building and to deny the access whenever necessary. Number of doors should be minimum possible. The size of the door should be of such dimension as will facilitate the movement of the largest object likely to use the doors.
•In case of the residental buildings, the size of the door should not be less than 0.9 m × 2.0 m. Larger doors may be provided at main entrance to the building to enhance the aesthetic view. Minimum sized doors are used for bath rooms and water closets. The size recommended is 0.75 m × 1.9 m. As a
thumb rule height of door should be 1 m more than its width.
image courtesy: various door vendors,various magaznes
