How can the water to cement ratio be calculated?
Water cement ratio is the relation between free water in a concrete mix to the total cementitious material.
Water cement ratio is calculated during process of concrete mix design base on the requirement specified for doing concrete mix design.
For better understanding you can refer below thread to understand how concrete mix designing is done.
