Key board function and shortcuts
Srinivasan
Administrator
Sep 7, 2017
1,014
1,549
mumbai
Button Function on keyboard
?⌨Ctrl + A : Select All
?⌨Ctrl + B: bold
?⌨Ctrl + C: copy
?⌨Ctrl + D: font
?⌨Ctrl + E : Center Alignment
?⌨Ctrl + F : Find
?⌨Ctrl + G: go to
?⌨Ctrl + H : Replace
?⌨Ctrl + I : Italic
?⌨Ctrl + J : Justify Alignment
?⌨Ctrl + K: insert hyperlinks
?⌨Ctrl + L : Left Alignment
?⌨Ctrl + M: Incrase indent
?⌨Ctrl + n: new
?⌨Ctrl + O: open
?⌨Ctrl + P: Print
?⌨Ctrl + Q: normal style
?⌨Ctrl + R : Right Alignment
?⌨Ctrl + S : Save / Save As
?⌨Ctrl + T : Hanging Indent
?⌨Ctrl + U : Underline
?⌨Ctrl + V: Paste
?⌨Ctrl + w: close
?⌨Ctrl + x: cut
?⌨Ctrl + Y: redo
?⌨Ctrl + Z: undo
?⌨Ctrl + 1 : Single Spacing
?⌨Ctrl + 2 : Double Spacing
?⌨Ctrl + 5 : 1,5 lines
?⌨Ctrl + ESC: start menu
?⌨F1: running the help function provided on word
?⌨F2: altering name a file / folder
?⌨F3: running orders command
?⌨F4: repeating previous orders
?⌨F5: running search and replace command or goto
?⌨F6.: running other command pane
?⌨F7: memeriksaan typos and text spelling (spelling)
?⌨F8: the beginning of the highlight / selection of text or object
?⌨F9 : Mengupdate Field (Mail Merge)
?⌨F10: enable menu
?⌨F11: entering the next field (mail merge)
?⌨F12: activating the us save dialog
?⌨ESC: cancel dialogue / command
?⌨Enter: perform an option or end a paragraph
?⌨Tab: move text according to the existing tab tags on horizontal ruler
?⌨Windows: Mengktifkan start menu
?⌨Shortcut: activating shortcut at cursor position
?⌨Delete: Remove 1 characters on the right of the cursor
?⌨Backspace: Removing 1 characters on the left of the cursor
?⌨Insert: Menyisip character in cursor position
?⌨Home: move cursor position to the beginning of the line
?⌨End: move cursor position to end of line
?⌨Page Up: Roll the screen up
?⌨Page Down: Roll the screen down
?⌨Up: MOVE CURSOR 1 line up
?⌨Down: MOVE CURSOR 1 line down
?⌨Left: MOVING CURSOR 1 characters to left
?⌨Right: MOVE THE CURSOR 1 characters to the right
?⌨Num Lock on: function typing numbers and active math operators
?⌨NUM LOCK OFF: Active Navigation button function
?⌨Shift + F10: open the shortcut, just like clicking right
?⌨Alt: button emphasis that is not combined with other buttons only Work to enable or start using bar menu
?⌨Shift + Delete: delete selected items permanently without placing items In Recycle bin
?⌨Ctrl + Right Arrow: move the insertion point to the beginning of the next word
?⌨Ctrl + Left Arrow: move the insertion point to the beginning of the previous word
?⌨Ctrl + Down Arrow: move the insertion point to the beginning of the next paragraph
?⌨Ctrl + Up Arrow: move the insertion point to the beginning of the previous paragraph
?⌨Alt + F4: close active items, or log out of active programs
?⌨Alt + Enter: displaying properties from selected objects
?⌨Alt + Spacebar: open the shortcut menu for active windows
?⌨Ctrl + F4: close active documents in programs that allow you To have some open documents simultaneously
?⌨Alt + Tab: switch between open items
?⌨Alt + ESC: cycle through items in an open order
?⌨Ctrl + shift + Tab: move backwards through tabs
?⌨Shift + Tab: move backwards through options
Version 2:
?⌨Ctrl + C (copy)
?⌨Ctrl+X (cut)
?⌨Ctrl+V (Paste)
?⌨Ctrl+Z (undo)
?⌨Delete (delete)
?⌨Shift+Delete (delete selected items permanently without putting items in recycle bin)
?⌨Ctrl while dragging (Men-drag) an item (copying selected items)
?⌨Ctrl + shift while dragging items (make shortcuts to selected items)
?⌨F2 Button (change the name of the selected item)
?⌨Ctrl + Right Arrow (move the insertion point (Cursor) to the beginning of the next word)
?⌨Ctrl + Left Arrow (move the insertion point (Cursor) to the beginning of the previous word)
?⌨Ctrl + Down Arrow (move the insertion point (Cursor) to the beginning of the next paragraph)
?⌨ Ctrl + Up Arrow (move the insertion point (Cursor) to the beginning of the previous paragraph)
?⌨Ctrl + shift with one of the arrow key (highlight text block)
?⌨Shift with one of the arrow key(Select more than one item in a window or on desktop, or select text in document)
?⌨ Ctrl + a (Select all)
?⌨F3 Button (looking for a file or folder)
?⌨Alt + Enter (view properties for selected items)
?⌨Alt + F4 (closing active items, or out of active programs)
?⌨Alt + Enter (display properties from selected objects)
?⌨Alt + Spacebar (Open Shortcut Menu for active windows)
?⌨Ctrl + F4 (closing active documents in programs that allow you to have some open documents simultaneously)
?⌨Alt + Tab (switch between open items)
?⌨Alt + ESC (cycle through items in an open order)
?⌨The F6. Button (cycle through the screen elements in the window or on desktop)
?⌨F4 Button (featuring address bar list on my computer or windows explorer)
?⌨Shift + F10 (Featuring Shortcut Menu for selected items)
?⌨Alt + Spacebar (system menu display for active windows)
?⌨ Ctrl + ESC (featuring start menu)
?⌨Alt + underlined letter in menu name (display the appropriate menu)
?⌨underlined letter in the name of the command on the open menu (do the appropriate command)
?⌨Button Button (enable bar menu in active program)
?⌨Arrow (open the next menu to the right, or open the submenu)
?⌨Left Arrow (open the left menu, or close the submenu)
?⌨Ann Button (updating active windows or refreshing)
?⌨Backspace (see folder one level up on my computer or windows explorer)
?⌨ESC (cancel duty now)
?⌨ Shift when you enter a CD-Rom into a CD-ROM (Prevent CD-Rom automatically playing / autoplay)
Keyboard Shortcuts Dialog Box
?⌨Ctrl + Tab (move forward through tab)
?⌨Ctrl + shift + Tab (move backwards through tab)
?⌨Tab (move forward through options)
?⌨ Shift + Tab (move backwards through choice)
?⌨Alt + underlined letters (do the appropriate command or choose the appropriate option)
?⌨Enter (do command for option or active button)
?⌨Spacebar (select or remove the checkbox if an active option is check box)
?⌨Arrow Tombols Arrow (Select a button if an active option is a selection button group)
?⌨F1 Button (featuring help)
?⌨F4 Button (showing items in active lists)
?⌨Backspace (open folder one level to the top if the folder is selected in save as or open the dialog box)
Microsoft Natural Tombolboard Shortcuts
?⌨Windows Logo (featuring or hiding the start menu)
?⌨Windows Logo + Break (Featuring System Properties dialog box)
?⌨Windows Logo + D (featuring the desktop)
?⌨ Windows Logo + M (minimize all windows)
?⌨Windows Logo + shift + M (restore minimized window)
?⌨Windows Logo + E (open my computer)
?⌨Windows Logo + F (search for a file or folder)
?⌨Ctrl + Windows Logo + F (search for computer)
?⌨Windows Logo + F1 (featuring windows help)
?⌨Windows Logo + L (Lock Keyboard)
?⌨Windows Logo + R (open the run dialog box)
?⌨Windows Logo + U (Open Utility Manager)
Accessibility Tombol board Shortcuts
?⌨Right shift for eight seconds (switch filtertombols on or off)
?⌨ LEFT ALT + LEFT SHIFT + PRINT SCREEN (Beralih High Contrast on atau off)
?⌨Left Alt + left shift + Num Lock (activate mousetombols on or off)
?⌨Shift five times (activate stickytombols on or off)
?⌨Num Lock for five seconds (activate toggletombols on or off)
Windows Explorer Tombolboard Shortcuts
?⌨End (displaying the bottom of the active window)
?⌨Home (showing the top of the active window)
?⌨Num Lock + Asterisk Sign (*) (show all subfolders that are under the selected folder)
?⌨Num Lock + Plus Sign (+) (featuring content from the selected folder)
?⌨Num Lock + minus sign (-) (collapse selected folder)
?⌨Left Arrow (collapse current option if expanded, or select main folder)
?⌨Right Arrow (featuring current selection, or select the first subfolders)
Shortcut Tombols for character map shortcut for character map
?⌨Once you click twice on the character character grid, you can move through the grid by using the shortcut Shortcut:
?⌨Right Arrow (move to the right or to the beginning of the next line)
?⌨Left Arrow (move to the left or to the end of the previous line)
?⌨Up Arrow (move to top one line)
?⌨Down Arrow (move down one line)
?⌨Page Up (move to top one screen at a time)
?⌨Down (move down one screen at a time)
?⌨Home (move to early line)
?⌨ End (move to end line)
?⌨Ctrl + Home (move to first character)
?⌨Ctrl + End (move to last character)
?⌨Spacebar (switch between the bigger and normal when a character is selected)
Microsoft Management Console (MMC) Main Window Tombol board Shortcuts
?⌨Ctrl + O (open that saved console)
?⌨Ctrl + N (open new console)
?⌨CTRL + S (Save the open console)
?⌨Ctrl + M (add or remove console items)
?⌨Ctrl + W (open new window)
?⌨ Alt + Spacebar (featuring mmc window menu)
?⌨ ALT + F4 (Close the console)
?⌨Alt + a (display the action menu)
?⌨Alt + V (featuring the view menu)
?⌨Alt + F (featuring the menu file)
?⌨Alt + O (featuring the favourites menu)
Console mmc window tombolboard shortcuts
?⌨ Ctrl + P (Print Active page or active pane)
?⌨ Alt + minus sign (-) (featuring an active console window window)
?⌨Shift + F10 (featuring the action menu shortcut for selected items)
?⌨ F1 Button (open the help topic, if any, for selected items)
?⌨Ctrl + F10 (Maximize Active Console Windows)
?⌨Ctrl + Ann (Restore Active Console Window)
?⌨Alt + Enter (display the properties dialog box, if any, for selected items)
?⌨ Ctrl + F4 (close the active console window. When a console has only one console window, this shortcut will close the console)
Remote Desktop Connection Navigation
?⌨CTRL+ALT+END (Open the m*cro$oft Windows NT Security dialog box
?⌨Alt + page up (switch between program from left to right)
?⌨Alt + page down (switch between program from right to left)
?⌨Alt + Insert (cycle through programs last used)
?⌨Alt + Home (featuring start menu)
?⌨Ctrl + Alt + Break (switch client computer between windows and full screen)
?⌨Alt+Delete (featuring the windows menu) Alt + Delete (featuring the windows menu)
?⌨Ctrl + Alt + minus sign (-) (creating a snapshot of the client's active window on the terminal server clipboard and provides the same function by pressing screen print on a local computer. )
?⌨Ctrl + Alt + Plus Sign (+) (create a snapshot of the entire client window area on the terminal server clipboard and provide the same function by pressing alt + print screen on local computers. )
Internet Explorer Navigation Internet Explorer navigation
?⌨ Ctrl + B (open favorite set dialog box)
?⌨CTRL + E (Open the select bar)
?⌨CTRL + F (Start the Find utility)
?⌨CTRL + H (Open the History bar)
?⌨ CTRL + I (Open the Favorites bar)
?⌨Ctrl + L (open open dialog box)
?⌨Ctrl + N (start another example of a browser with the same web address)
?⌨Ctrl + O (open dialog box, just like ctrl + L)
?⌨Ctrl + P (Open Print dialog box)
?⌨Ctrl + R (updating this web page)
?⌨Ctrl + W (close window active)
?⌨ Prin Scrn + Active Printer (Printing Snapshot / overall window)
?⌨Alt + Print Scrn + Smart Active (Printing Windows Active)
?⌨Shift + F3 (1 x) (Capital front letter)
?⌨Shift + F3 (2 x) (all uppercase / big letters)
?⌨Shift + F3 (3 x) (all small letters)
gatturam
9
4
hyd
?⌨Ctrl + B: bold
?⌨Ctrl + C: copy
?⌨Ctrl + D: font
?⌨Ctrl + F : Find
?⌨Ctrl + G: go to
?⌨Ctrl + I : Italic
?⌨Ctrl + n: new
?⌨Ctrl + O: open
?⌨Ctrl + P: Print
?⌨Ctrl + V: Paste
?⌨Ctrl + w: close
?⌨Ctrl + x: cut
?⌨Ctrl + Y: redo
?⌨Ctrl + Z: undo
?⌨F10: enable menu
Version 2:
?⌨Ctrl + C (copy)
?⌨Ctrl+X (cut)
?⌨Ctrl+V (Paste)
?⌨Ctrl+Z (undo)
?⌨Delete (delete)
VERY USEFUL SIR
