Kindly differentiate about acrylic based and cement based waterproofing. Advantages and disadvantages in detail
veera1234
Apprentice
Dear team, I would like to know about waterproofing in detail about the above mentioned. Kindly give the answer for why this n why not this regarding both
The one-liner comparison misses the most important part — neither system is universally better.
The right choice depends entirely on substrate condition, exposure, and what failure you're
trying to prevent.
Cementitious waterproofing (polymer-modified slurry, 2-component systems like SikaTop Seal
107, Ardex WPM 004, Dr. Fixit Dampguard):
— Bonds directly to concrete/masonry. No debonding risk from substrate movement.
— Rigid to semi-rigid — handles hydrostatic pressure well (basements, water tanks, sunken slabs).
— Zero crack-bridging ability above ~0.2mm. If the substrate moves or cracks after application,
the coating cracks with it.
— Best for: bathrooms, water tanks, sunken areas, basement walls where substrate is stable.
Acrylic/polymer membrane (liquid-applied flexible membranes):
— Elongation of 150-300% — bridges hairline and shrinkage cracks effectively.
— UV-stable grades work on exposed terraces. Cement systems chalk and degrade in direct sun.
— Needs a protection screed on trafficked surfaces — exposed membrane alone won't survive foot
traffic.
— Bond to substrate is adhesive, not chemical — surface prep is critical. Any dust, laitance or
contamination = debonding.
— Best for: terraces, roof slabs, external walls, anywhere with thermal cycling or expected
minor movement.
The mistake I see constantly in India: applying flexible acrylic on basement walls (wrong —
can't handle hydrostatic pressure from outside) and applying rigid cementitious coating on
terraces (wrong — no crack bridging, fails at first monsoon after any shrinkage).
For sunken bathroom slabs specifically: 2-component polymer-modified cementitious system
applied directly on the structural slab before any screed. Not acrylic, not brick bat coba
alone.
What's the specific application — terrace, basement, bathroom, or external wall? Changes the
answer significantly.
I write about waterproofing systems and material selection for Indian conditions weekly at
builtbychemistry.com?utm_source=forum&utm_medium=comment&utm_campaign=civil4m — working
out of Rajasthan, I see these misapplication failures regularly.
