Lab Test Format - Determination of In Situ Density by Nuclear Density Gauge
With the help of Nuclear Density Gauge one can quickly find out the actual dry density and compaction factor of soils.
This is use to get quick results of compacted base material properties (In order to do that one should know the maximum dry density and optimum moisture content of base material for which test is being carried out).
The format for recording result for the same is attached herewith.
  • C4M In Situ Density Test by Nuclear Density Gauge .xlsx
