Non-Destructive Testing (NDT) Methods for Concrete Structures: As Per Indian Standards
satyace
Junior Member
Non-Destructive Testing (NDT) of concrete structures enables engineers to evaluate the quality, consistency, and integrity of in-situ concrete without destroying the structure. According to Bureau of Indian Standards (BIS) and Ministry of Road Transport and Highways (MoRTH) guidelines, NDT is essential for assessing structures prior to retrofitting, widening, or in the event of suspected distress.
Significance of Non-Destructive Testing NDT in Concrete Inspection
Non-Destructive Testing NDT techniques are typically applied for:
  • Compressive strength estimation (with calibration).
  • Detection of internal defects or cracks.
  • Assessment of uniformity and homogeneity.
  • Age or environmental cause deterioration detection.
IS 13311 (Part 1 & 2) gives standard practices for NDT of concrete structures in India.
Standard Non-Destructive Testing NDT Techniques (According to IS Codes)
Rebound Hammer Test A Non Destructive Test NDT for Concrete Inspection
Standard Code: IS 13311 (Part 2): 1992
  • Rebound Hammer Test Application: Surface hardness to estimate concrete compressive strength.
  • Principle: Records rebound number (R) of plunger impacting the concrete surface.
  • Use: Preliminary investigation or along with other tests.
  • Limitation: Influenced by surface roughness, moisture, carbonation.
Rebound Hammer Test Indicative Strength Estimation:
  • Rebound Number less than 20 the Approx. Compressive Strength is Less than 10 (MPa).
  • Rebound Number less than 20–30 the Approx. Compressive Strength is between 10 to 25 (MPa).
  • Rebound Number Greater than 30 the Approx. Compressive Strength is greater than 25(MPa).
(Actual calibration curves should be established based on core results per IS 13311.)
Ultrasonic Pulse Velocity (UPV) Test for A Non Destructive Test NDT for Concrete Inspection
Standard Code: IS 13311 (Part 1): 1992
  • Purpose : Assesses uniformity, voids/cracks, and quality.
  • Principle: Measures ultrasonic pulse velocity through concrete.
  • Equipment: UPV meter with transducers (50-150 kHz).
  • Wave Modes: Direct, semi-direct, and indirect transmission.
Guidelines for Ultrasonic Pulse Velocity (UPV) Test Interpretation:
  • Pulse Velocity (km/s) Concrete Quality greater Than 4.5 is Excellent.
  • Pulse Velocity (km/s) Concrete Quality between 3.5 to 4.5 is Good.
  • Pulse Velocity (km/s) Concrete Quality between 3.0 to 3.5 is Doubtful.
  • Pulse Velocity (km/s) Concrete Quality below 3.0 is Poor.
Core Cutting Test (for Calibration)
Standard Code: IS 456:2000; IS 516:1959
  • Purpose: Get concrete samples for direct compressive strength test.
  • Role in NDT: Core results are used to calibrate indirect NDT values.
  • Core Diameter: Generally 75 mm or 100 mm.
  • Correction Factor: Used for cores with height/diameter <2.0.
Penetration Resistance Test
Standard Code: ASTM C803M (referenced in Indian practice – to be verified)
  • Principle: Test for depth of penetration of a hardened steel probe.
  • Application: Method used when rebound hammer is not possible.
Note: Very restricted usage in India; not included in IS 13311, therefore indicated as "to be verified".
Pull-Out Test
Standard Code: ASTM C900 (referenced in Indian literature – to be verified)
  • Principle: Test for force to pull out a metal insert from concrete.
  • Application: Provides localized compressive strength information.
Code-Based Guidelines and Acceptable Limits​
From IS 456:2000 Minimum Compressive Strength at 28 days:
  • M20: 20 MPa
  • M25: 25 MPa
  • M30: 30 MPa
From MoRTH (Section 1700)
  • Recommends NDT techniques for bridge deck inspection and routine examination.
  • Cannot utilize UPV and rebound hammer test in periodic structural evaluation.
Limitations and Precautions of Non Destructive Test NDT
  • NDT cannot replace standard cube tests for acceptance.
  • Always validate results with core testing for reliability.
  • Environmental conditions (temperature, moisture) can affect readings.
  • Use trained personnel as per IS 13805:1993 (for rebound hammer).
