If we use the rebar coupler for column lapping,is it necessary to maintain the lapping length of 50D difference to avoid the 100% lapping of tmt bar at a section?
plz help me.
plz help me.
plz help me.
Hi,However we need to ensure staggeredness in rebars by ensuring not all couplers are installed at same level.
sir, if you can please share a image for staggered rebars with couplers..
Hi,
Very important information can any one share the methodology for reinforcement coupling preparation and need cost for each Bar threading as we don't have space for lathe setup at site considering my site condition is small so i have to out source for reinforcement threading
ThankuContact Mr. Shankar Rajput they have a facility of mobile truck they come to your site and do the threading works on site. Contact number 9821090440 for rates etc you can contact him.
Please contact at 9540062214 or rmengineers.info@gmail.com for high-quality rebar couplers and bestplease i need the list of tested and trusted brand of rebar
Please contact at 9540062214 or rmengineers.info@gmail.com for high-quality rebar couplers and best rates.Thanku
When u use coupler no need of lappingIf we use the rebar coupler for column lapping,is it necessary to maintain the lapping length of 50D difference to avoid the 100% lapping of tmt bar at a section?
plz help me.
YesHas to maintain staggering of 50% bars at one level and 50% bars at other level....
Sir Can we use couplers in beamsFirst of all you should understand what is mean by coupler.
You can also do search in google for couplers to know more about it.
In plumbing or electrical system, two pipes are jointed together with the help of socket, in plumbing specifically when GI pipes are use, sockets do have threading on it and pipe which goes into socket too have the threading on it.
Same way rebars which are fixed in column do have threads on it. the coupler which is used to join two bars one above another do have threading in it.
The bars are joint together in straight line by tightening it on the coupler. when couplers are used, there is no lapping required as it joins rebars point to point.
