satyace
Why Test the Strength of Concrete?​
Concrete strength is the heartbeat in the world of civil engineering. It decrees safety, longevity, and load-carrying capacity, but as buildings age or are faced with harsher environments, that strength can change.
While "destructive testing" (like taking core samples) yields very accurate data, one is not always in a position to create holes in a working bridge or a skyscraper. It is here that NDT comes to the rescue. Of these techniques, the Rebound Hammer Test certainly is the most common "first-look" diagnostic tool.
What is the Rebound Hammer Test ?​
Also called the Schmidt Hammer Test, this is a portable, non-destructive method to check the surface hardness. This test works by striking the concrete with a spring-loaded mass, and by measuring the amount of energy that "rebounds" back.
This Rebound Number serves as an indirect representation of its compressive strength. Engineers worldwide prefer the test because:
  • Fast: Obtain your results in seconds.
  • Cost-effective: The cost of equipment and labor is small.
  • Non-Invasive: Zero damage to the structural integrity.
How the Rebound Hammer Test Works: The Science of the “Bounce”​
This is a basic principle: The harder materials are, the less energy they absorb. What happens when the plunger of the hammer impacts the concrete:
  • Impact: The kinetic energy is transferred to the surface.
  • Absorption: The softer concrete will absorb more energy (lower rebound
  • The Result: The harder concrete will reflect more energy. This leads to a higher Rebound Number.
Note: Rebound number is an indirect measure. For a correct measure of strength, comparison with calibration curves (ASTM-C805 or IS 13311, for instance) needs to be done.
Getting the Best Results: Preparation and Procedure​
There is no "point and shoot." It takes precision to follow the procedure.
1. Surface Preparation​
The surface of the concrete also has to be clean and smooth. Dust, paint, and other loose matter on the surface act as a "cushion" and will spoil your data.
  • Use a grinding stone to plane the surface.
  • Honeycombing or large cracks should be avoided.
2. The Standard Procedure​
  • Angle: The angle is always perpendicular (90 degrees) to the surface.
  • Repetition: Make at least 10 readings in a small testing area.
  • Averaging: Remove any values that lie outside statistical tolerances. Then, calculate the average.
BENEATH THE SURFACE: REBOUND HAMMER Test VS Ultrasonic Pulse Velocity (UPV) Test ​
However, if we want to rank our article and give information of value, it is necessary that we compare the hammer with its counterpart, the Ultrasonic Pulse Velocity (UPV).
FeatureRebound Hammer TestUltrasonic Pulse Velocity (UPV) Test
Primary GoalSurface HardnessInternal Integrity
ComplexityVery Low (Easy)Moderate (Requires training)
DetectionSurface strength & uniformityVoids, internal cracks, and density
CostBudget-friendlyHigher investment
Expert Advice for 2026: Common Traps to be Avoided​
If a level of professional accuracy is desired, here are a few "insider" tips to keep in mind
  • The Carbonation Factor: The concrete concrete will react with CO_2, forming a hard surface layer. This will result in a "false high" reading on the hammer test. Always test carbonation if the concrete is more than 20 years old.
  • Moisture Matters: Wet concrete will always provide lower rebound values than dry concrete of the same strength.
  • The 25mm Rule: The impacts should be spaced at least 25mm apart. Hitting the same spot twice will create inaccurate results. This is because the first impact will compact the material.
Rebound Hammer A Reliable NDT Technique The First Line of Defence:​
Rebound Hammer Testing’s value in determining the initial analysis of concrete cannot be underestimated. While Rebound Hammer Testing should never be considered the lone determinant in structural integrity, the speed in which Rebound Hammer Testing can evaluate sections for weakness and homogeny cannot be ignored.
