Dqspathum Junior Member india Jun 19, 2018 #1 I need to help to write answer for this question? please look at the attach image thank u!
Dnyan Deshmukh Staff member Pune Jun 24, 2018 #2 i am not a surveyor but i did survey in my collage time. Base on it i made a sample raw format survey field book (you need to format it to as you want to have its look). there is an error of 2mm in surveying record, you need to normalize and do correction in reduce levels as per you learn in collage or referring books. Reduce levels of foundation bottom and top are calculated without adjusting the error. attachment snapshot survey field book with calculation is attached herewith Attachments C4M Survey Field Book.xlsx C4M Survey Field Book.xlsx 9.2 KB · Views: 34 Reactions: VIDHYA SAGAR and Pankaj Sharma Upvote 0 Downvote
