Templates for Construction work office documentation
Hello,
I am attaching the important templates which generally used for construction process from pre-construction stage to post construction stage.
These are the most important formats which are required in any kind of projects, the attached formats includes;
- BOQ Quantity Validation
- Cash Outflow
- Change order for Purchase Order Quantity.
- Detailed Cost Plan
- Draft Estimate
- RA bill Abstract
- Rate Analysis
- Reinforcement steel calculations
- Variation Statement
I hope it will helpful to you to prepare the documents at your office
  • BOQ Quantity Validation-Peer review Auditing.pdf
  • Cash outflow.pdf
  • Change Order for PO Qty.pdf
  • Detailed Cost Plan.pdf
  • Draft Estimate.pdf
  • RA Bill Abstract.pdf
  • Rate Analysis.pdf
  • Reinforcement Steel Calculations.pdf
  • Variation statement.pdf
Hello,
- Cash Outflow
- Draft Estimate
- RA bill Abstract
- Rate Analysis
Brother,
I want to know more about this rate analysis..Can you help?
Reactions: daivik31 and Basith
pirpasha
Hello,
- Cash Outflow
- Draft Estimate
- RA bill Abstract
- Rate Analysis
It will be more helpful if upload excel sheet of these files.. if you have.
Reactions: Mohammed Muaviya
Hello,
- Cash Outflow
- Draft Estimate
- RA bill Abstract
- Rate Analysis
Thanks Sir
Hello,
- Cash Outflow
- Draft Estimate
- RA bill Abstract
- Rate Analysis
Please send excel files
I see several members have asked for the templates in Excel rather than pdf. I, like Mr. Sudhakar Reddy B will often provide my spreadsheet-based templates in pdf format rather than provide the actual worksheet: Why? Blindly using someone else's spreadsheet without a full understanding of the calculations & functions used to build it can lead to disastrous results. As an engineer, you must take it upon yourself to build & understand your own worksheets. Mr. Sudhakar has provided some excellent starting points, but it's up to the individual engineer to put in the time & effort to craft worksheets that work for your particular project or problem set....
The world is changing so quickly - Younger generations are expecting an App to solve their problems with a push of a button instead of putting in the hours of work necessary to solve the problem using their own minds. We are engineers - We are different - Our minds are built to solve problems. Take the initiative. Drive yourself to solve the problem on your own. Don't always look for the "Push Of A Button" solution. You are educated, trained and possess talents & skills far beyond the non-engineer. The engineer who puts in the work and applies his/her knowledge is a much greater asset to his team, client & employer than someone who simply knows how to use an App....
