  • LOUNGE
  • MCQ Questions
  • Reinforced Concrete - MCQ
The allowable direct compressive stress in high yield deformed bars in RCC columns in liquids is in M p a -
  • Thread starter Thread starter Dnyan Deshmukh
  • Start date Start date Jan 17, 2018
Pune
  • Jan 17, 2018
(a) 1500
(b) 1900
(c) 2300
(d) 1400
The correct Answer Is
(b) 1900
Reactions: Sumit Civil
Srinivasan
  • Srinivasan
  • Feb 9, 2018
Feb 9, 2018
Srinivasan
Srinivasan
Srinivasan
  • Srinivasan
  • Feb 9, 2018
Feb 9, 2018
Srinivasan
Srinivasan
Srinivasan
  • Srinivasan
  • Feb 9, 2018
Jun 6, 2019
Ayuba
Ayuba
Srinivasan
  • Srinivasan
  • Feb 9, 2018
Feb 9, 2018
Srinivasan
Srinivasan
Srinivasan
  • Srinivasan
  • Feb 8, 2018
Feb 8, 2018
Srinivasan
Srinivasan
