    New posts Search forums
What's new
By:
Advanced search…
By:
Advanced…
  • Search forums
  • LOUNGE
  • MCQ Questions
  • Reinforced Concrete - MCQ
The maximum percentage of reinforcement in RCC pedestals is about -
  • Thread starter Dnyan Deshmukh
  • Start date Jan 17, 2018
Pune
  • Jan 17, 2018
(a) 0.8
(b) 2.0
(c) 4.0
(d) 6.0.
The correct Answer Is
(d) 6.0
Reactions: Sumit Civil
S
SKK
Active Member
Delhi
  • Nov 30, 2019
  • #2
Answer is (a) 0.8.........................................
Srinivasan
  • Srinivasan
  • Feb 9, 2018
Feb 9, 2018
Srinivasan
Srinivasan
Srinivasan
  • Srinivasan
  • Feb 9, 2018
Feb 9, 2018
Srinivasan
Srinivasan
Srinivasan
  • Srinivasan
  • Feb 9, 2018
Jun 6, 2019
Ayuba
Ayuba
Srinivasan
  • Srinivasan
  • Feb 9, 2018
Feb 9, 2018
Srinivasan
Srinivasan
Srinivasan
  • Srinivasan
  • Feb 8, 2018
Feb 8, 2018
Srinivasan
Srinivasan
