  • LOUNGE
  • MCQ Questions
  • Steel Structures - MCQ
The maximum permissible sag in steel beams is -
  • Thread starter Thread starter Dnyan Deshmukh
  • Start date Start date Jan 17, 2018
Pune
  • Jan 17, 2018
(a) 0.0
(b) 5 mm
(c) 10 mm
(d) 15 mm.
The correct Answer Is
(d) 15 mm
Reactions: Sumit Civil
H
Help with designing lifting ring
  • harek96
  • Oct 14, 2023
Oct 14, 2023
harek96
H
Design of steel structure - mcq questions and answers
  • archdevil
  • Nov 4, 2019
Nov 4, 2019
The tolerance in the diameter of bolt holes is about -
  • Dnyan Deshmukh
  • Jan 18, 2018
Nov 29, 2019
sane123
S
The tolerance in the pitch of bolt holes is about -
  • Dnyan Deshmukh
  • Jan 18, 2018
Jan 18, 2018
The tolerance in the alignment of rails on plate girder is about -
  • Dnyan Deshmukh
  • Jan 18, 2018
Jan 18, 2018
