The pressure in the air space above an oil (sp. gr. 0.8) surface in a tank is 0.1 kg/cm".
The pressure at 2.5 m below the oil surface will be
(a) 2 meters of water column
(b) 3 meters of water column
(c) 3.5 meters of water column
(d) 4 m of water column
(e) none of the above.
The correct Answer Is
