A foundation is the structural element that transmits building loads safely to the ground. The selection of the appropriate type of foundation involves both an understanding of the structural requirements and the nature of the soil on site. Different soils require different foundation solutions, so the investigation of soil conditions is a critical activity prior to the commencement of any construction. This article describes the major foundation types and identifies fundamental soil considerations, which influence foundation design.
Shallow foundations are used where adequate load-bearing soil exists near the ground surface, generally within a depth of about 3 meters. These foundations distribute structural loads over a broad area and are commonly used for low- to medium-rise construction where the near-surface soils can safely support the load.
It is usually chosen in cases:
They are characterized by:
This type of footing:
It is usually used when:
Key features of Pile foundations include:
Pile foundations provide strength and stability when shallow options are not feasible.
They are selected when:
They are particularly effective in:
This foundation is used when:
Understanding the types of foundations and their appropriate applications is paramount for ensuring structural stability and long-term performance. Shallow foundations can be used for firm, near-surface soils, while deep foundations are required if loads need to reach stronger materials deeper within the ground.
In cases where soils behave unusually or present a problem, special foundations offer solutions.
The selection of a type of foundation essentially calls for the evaluation of certain properties of the soil, including bearing capacity, compressibility, and moisture characteristics.
Accurate soil evaluation and proper selection of foundations can provide structures with the necessary support, safety, and longevity in a wide range of ground conditions.
1. Shallow Foundations
a. Strip Foundation
A strip foundation is a continuous band of concrete placed beneath load-bearing walls.It is usually chosen in cases:
- The soil conditions are firm and uniform.
- The load from the structure is distributed linearly.
- Settlement risks are minimal.
b. Pad / Isolated Footing
Pad or isolated footings are individual concrete blocks supporting single columns.They are characterized by:
- Shapes are usually square, rectangle, or circular.
- Relatively low to moderate loads.
- Flexibility in size, depending on column load and soil bearing capacity.
c. Combined Footing
A combined footing is used to carry two or more columns, especially those that are close together, or when one column is at an edge where a separate footing cannot be centered.This type of footing:
- Allows even distribution of loads from adjacent columns.
- Prevents eccentric loading issues.
- Provides greater area of support when space is at a premium.
d. Raft / Mat Foundation
A raft or mat foundation covers a large area, essentially covering the full footprint of a structure.It is usually used when:
- The soil has a low bearing capacity.
- The loads from columns or walls are closely spaced.
- Differential settlement should be minimized.
2. Deep Foundations
Deep foundations transfer loads through the weak surface soil layers to deeper, competent soil or rock strata. They become necessary in cases where the upper soil cannot safely support structural loads, especially for high-rise buildings and industrial structures, or in areas with highly variable ground conditions.a. Pile Foundation
Pile foundations are lengthy, slender members, either driven, drilled, or bored into the ground to reach stronger layers.Key features of Pile foundations include:
- Ability to transfer loads through either end-bearing or skin friction.
- Suitability for sites with loose sand, soft clay, or water-logged conditions.
- Compatibility with heavy loads and deep soil deposits.
- End-bearing piles: These transfer loads directly to hard layers or rock.
- Friction piles rely on friction between soil and the pile surface.
- Steel piles: Used in marine and industrial situations.
b. Pier / Caisson Foundation
Pier or caisson foundations are those for which large-diameter shafts are drilled into the ground until competent soil or rock is reached.They are selected when:
- Very heavy loads must be supported.
- Control of the groundwater is required.
- Deep, stable strata can be accessed by drilling.
3. Special Foundations
In such soil conditions, there are special designs for foundations to counteract soil movements and low strength or to avoid excessive settlement. Special foundations are specifically designed for unique ground behaviors that typical shallow or deep systems cannot manage effectively.a. Under-Reamed Piles
Under-reamed piles are piles with bulb-shaped enlargements near the base.They are particularly effective in:
- Expansive soils, like black cotton soil.
- Areas experiencing soil swelling and shrinkage.
- Circumstances that require the resisting of uplift forces.
b. Floating Foundation
The concept of a floating foundation also relies on the key idea of balancing the weight of the structure with the weight of excavated soil.This foundation is used when:
- The soil is very weak or compressible.
- Settlement control is critical.
- Traditional foundation types are not practical.
Soil Type to Foundation Type (Quick Guide)
| Soil Type | Recommended Foundation |
| Dense Sand / Gravel | Shallow foundations (strip, pad, raft) |
| Soft Clay | Raft or pile foundation |
| Loose Sand | Pile foundation |
| Expansive Soil (Black Cotton Soil) | Under-reamed piles |
| Very Weak Soil | Pile or Floating foundation |
| Rock | Shallow stepping or pad foundation |
