Types of injection grouting and applications in construction project
Injection grouting is a process of filling the cracks, voids or honeycombs under pressure in concrete or masonry structural members for repairing of cracks, strengthening of damaged concrete or masonry structural members.
Grout is a flowable plastic material and should have negligible shrinkage to fill the gap or voids completely and should remain stable without cracking, de-lamination or crumbling.
There are different types of grouts used for repair and strengthening of concrete and masonry structural members. The selection of type of grout for particular type of concrete or masonry repair work should be based on the compatibility of the grout with the original material.
Types of Injection Grouting and Materials for Concrete Crack Repair
Following are the various types of injection grouting and materials for concrete crack repair:
Polymer injection grouting
Fiber-reinforced injection grouting
Cement sand grouting
Gas-forming grouting
Sulfo-aluminate grouting
Polymer Injection Grouts:
Polymer injection grouting is based on use of polymers such as polyester, epoxy, polyurethane and acrylic resins. The most popular polymer used for epoxy grout is epoxy. Polyurethane and acrylic resin based polymers are used for treatment of water retaining structure, underground structures as well as to prevent seepage of water.
The polymer injection grouts are available in three component materials and two component materials. The three component materials grout includes:
Liquid resin content,
Curing agent or hardener,
Aggregate or dry filler.
The two component materials grouts include:
Aggregate or dry fillers.
The polymer injection grouts are can have be made suitable for repair works by adding modifiers to basic resins and curing agents to achieve the desired properties. These vary from manufacturer to manufacturer, and therefore should always be used based on manufacturer’s recommendations.
Following are properties of different types of Polymer Based Injection Grouting:
Epoxy based injection grouts possess low pot life, non-resistant to ultraviolet exposure and high temperatures, non-shrink, flowable, effective in sealing cracks, excellent bonding with almost all building materials, good chemical resistance.
Lignosulfonate based injection grout admixture lowers viscosity of cement slurry, compensates drying & plastic shrinkage.
Fiber-Reinforced Injection Grouts
Fiber reinforced concrete is used for repair of concrete and masonry structural members. Fibers such as polypropylene, Steel or Glass fibers are used with Portland cement or shrinkage compensating mortar to repair and strengthening of structural members to provide improved flexural strength, impact resistance and ductility. Fiber reinforced injection grouts require skilled handling to avoid segregation of fibers.
Cement Sand Grouts
Cement-sand grout is the most popular type of grout used for repair of concrete or masonry structure and is easily available. This grout is used for the places where strength enhancement of structure is not required. This is also most popular because it is readily available in the market and is cheapest form of repair of concrete and masonry structural members.
Gas-forming Grouts
The gas-forming injection grout is used based on the principle that the gas bubbles expand the grout to compensate shrinkage of grout after application. These gas bubbles are generated on reaction of some ingredients (usually Aluminium and Carbon powder contained in grout) with the cement liquor.
The gas bubble forming injection grouts are temperature sensitive and is not suitable for high temperature application require proper confinement to develop strength and volume stability, as the reaction forming gas bubbles may be too fast and may complete before placing of the grout.
Sulfo-aluminate Grouts
Sulfo-alum injection grout is also based on the principle shrinkage compensation. In these grouts either shrinkage-compensating cement or anhydrous sulfo-aluminate expansive additive is used with Portland cement. The additive results, in expansion at hydration.
This produces expansion after the grout has set and is more reliable than gas -forming grouts. But the expansion of such grouts requires post-hardening curing and it will not be effective if moist curing is not available.
Cement Sand Grouts
Gas-forming Grouts
