  • LOUNGE
  • MCQ Questions
  • Massonary Structures - MCQ
What is a Brick Work Material Calculator?
  • Thread starter Thread starter soved.in
  • Start date Start date Oct 1, 2025
  • Tags Tags
    brick masonry brick work brick work material calculator bricks brickwork and mortar calculations civil civil engineer specilize civil engineering
soved.in
soved.in
Lucknow
  • Oct 1, 2025
A Brick Work Material Calculator is an online tool that calculates the number of bricks, amount of cement, and sand required for building walls based on wall dimensions, brick size, and mortar thickness.1000057110.png
Try calculator
  • Screen_Recording_20250824_162915_Spck Editor.mp4
    15.9 MB
For the purpose of computing the slenderness ratio in masonry columns, the effective height of a free-standing wall is -
  • Dnyan Deshmukh
  • Jan 17, 2018
Feb 4, 2020
Rajesh KUMAWAT
R
The allowable shear stress in stone masonry with 1 : 6 cement mortar is about in Newton per cm square is -
  • Dnyan Deshmukh
  • Jan 17, 2018
Jun 24, 2019
Etahamit
Etahamit
The allowable modulus of rupture in masonry under live loads is about -
  • Dnyan Deshmukh
  • Jan 17, 2018
Jan 17, 2018
The allowable tensile stress in brick masonry under wind load conditions is about in Newton per cm square is -
  • Dnyan Deshmukh
  • Jan 17, 2018
Jan 17, 2018
The allowable tensile stress in masonry retaining walls under earth pressure is about in Newton per cm square -
  • Dnyan Deshmukh
  • Jan 17, 2018
Jan 17, 2018
