Bars are bent near the supports at an angle of 45°. The angle bent may also be 30° in shallow beams where the (effective depth< 1.5 breadth).
Bars are bent near the support to
- To resist negative bending moment (hogging).
- To resist shear force which is greater at supports.
- To reduce the risk of a brittle failure of slab-column connection.
Slab is supported at two ends. The maximum tensile stress is in the middle of the slab and the maximum compressive stress is at both ends.
To make RCC slab safe from compressive stresses we place reinforcement in form of bent up bars.
When bent up bars are provide the strength and deformation capacity of slabs with bent up bars compared to slabs without bent up bars is sufficiently increased.
