Which material is used to firmly fix a stone slabs on concrete?
to fix the stone on concrete you can use cement paste or adhesive which you think best suitable for your work.
Both are good for fixing stone.
If you are going to use it for stone cladding on concrete wall surface, do ensure to make back surface of stone is made rough to form a mechanical key for bonding. it can be done by spreading resin hardener on back of stone and sprinkling big size sand on it.
You can also use brackets, if the height of installation exceeds 2 meter and where stones are installed in more than 2 pieces one above other.
