There are many reasons due to which, honeycombing occurs in concrete.
Particularly about your issue.
- gaps at shutter at bottom shows slurry loss and small honey combing.
- Mix look like do not have proper workability (If you are using one bag mixer to produce a concrete, then variation may be occurred in each batch, if not using water dispenser for pouring water in mix)
- If you are using RMC / or doing batching with one bag mixer.
there may be a gap in concrete occurred due to
vibrator was not working
labour gone for lunch
or some other issue which stopped the concreting activity for sometime.
This are the basic issue which may happens and concrete get spoiled.
Now Come to a structural issue
- column looks like heavily reinforced
There is a possibility that, concrete have low workability and the vibrator cant go inside properly due to heavy reinforcement and due to improper or no compaction this issue get arise.
Remedy
- the easiest and cost saving remedy is to break the column and recast (if you can see through the honey comb or water passes from one end to another) Its not good to rectify cavity in compression member.
- You can rectify such pockets either by doing a self compacting concrete or micro concrete inside it (This is costly and not recommend, If the structure above is already built and later we came to know about such pockets, we can do this instead of breaking whole structure).
To avoid such issue in future you can implement following
- Redesign the mix with required parameters like workability, retention time etc.
- Ask your structural consultant to do some changes in design, if you cant compact concrete by inserting needle.
- Ensure vibrator needle is having sufficient length for insertion.
- Do keep backup alternative like vibrator which have diesel engine, to ensure compaction during no electricity or failure of electricity supply.
- In case of bag mixer, use electrically operated water dispenser which dispense the amount of water which we set.
- Ensure all working platform, material, manpower and machinery required for concrete are available before starting concrete (after starting concrete if you search for vibrator or any other equipment/ manpower, it will cause some issue in concrete)
Enjoy happy concreting by taking care of above points
