It is important to check the block masonry work done correctly to ensure no extra plaster thickness on walls and avoid cracks on wall surface during hand over stage.
This checklist will help you to ensure checking of all points related to Block Masonry Work.
Checklist of Block Masonry Work consist of following checkpoints in it;
- Approved architectural drawings are available on site
- RCC slab surface is cleaned properly
- Line out checked as per drawing. (first layer)
- Fish wire pulled through conduits and beam bottom cleared
- RCC column/wall surface roughened /mortar dash applied
- Mortar mixing proportion as specified ( )
- M.S. trays used for mortar mixing .
- Mortar used within 45 minutes after mixing .
- Independent scaffolding system done for masonry
- Provision for door openings/ window openings /architectural features if any checked
- RCC band provided for 100mm block masonry at 1.5m level.
- Staggering of joints ensured
- Proper bond/ anchorage with cross wall checked
- Masonry joints not more than 10mm
- Racking of joints done
- Rich mortar/metal packing provided for RCC /masonry joint.
- Construction date marked on wall
- Curing of masonry ensured for at least 7 days
