External Plumbing Works
External Plumbing is important work and plays vital role in success of any project, ensure you do correct work as per the checklist created by you.
Checklist of External Plumbing Works consist of following checkpoints in it;
Procedures to be followed before external plumbing
Procedures to be followed during external plumbing
Procedures to be followed after external plumbing
Sample checklist for external plumbing work is attached herewith.
- Latest Architectural Drawings available on site
- Marking of pipelines on outer walls done
- G I pipe sleeves provided in RCC walls of UGWT and OHWT
- Positions of outlet pipes marked and holes drilled as specified
- CPVC pipes are visually inspected for cracks
- Cutting of G I pipes and threading as specified (if any)
- Entry of pipes through walls should be at right angles
- Assembly and fixing of G I pipes in position as specified (if any)
- Anticorrosive treatment to G I pipes as specified (if any)
- CPVC pipes are cut and installed as specified
- Sufficient gap kept between wall surface and pipes provided
- Joinery done as specified (if required) G I to CPVC
- Clamps for CPVC pipelines as specified
- Expansion loop provided for CPVC pipelines (if specified)
- Pressure reducing valves / mechanism provided
- Checks on UGWT / OHWT carried out as specified
- Vent pipes and clean out provision for OHWT provided
- Masonry chases/ holes rendered with non-shrink grout
- Gravity Pressure Testing carried out as specified
- Leakages, if any, are corrected after Pressure Test as specified
