Work Checklist - Internal Plumbing Work
Checklist for internal plumbing work is attached in this post.
Checklist consist following checkpoints in it;
Procedures to be followed before internal CPVC plumbing - Pre
  • Manufacturer's test certificate / Installation Guide available(CPVC)
  • Architectural / plumbing drawings available on site
  • Proper lighting arrangement ensured in dark areas
  • Toilet walls are marked with tile fixing positions
  • Toilet floor is marked with positions of EWC,Bath tub and other WC fitting
  • Tile thiyyas are taken as specified to decide finished tile plane
  • Positions of flush tanks/Boiler marked on walls
  • Drainage outlet holes marked on walls
  • All trap positions marked
  • Chasing of masonry done as specified (cutter machine used)
Procedures to be followed during internal CPVC plumbing - During
  • CPVC pipes visually inspected for cracks
  • CPVC pipes are cut and installed as specified (round wheel cutter used)
  • Solvent cement used for jointing CPVC pipes as specified (check for expiry date)
  • Pipe inserted in fitting by rotating 1/4 to1/2 turn for even distribution of solvent cement.
  • Plastic clamps from the same manufacturer used at approx.900mmc/c (avoid metal clamps)
Procedures to be followed during internal CPVC plumbing - Post
  • Pressure Testing carried out as specified (8-10 kg/sq.cm or 1 1/2 times the design pressure)
  • Leakages, if any, are corrected after Pressure Test
  • Filling (rendering )of chases done using non-shrink grout and cured for 4 days.
  • C4M Internal Plumbing Works.docx
