Post Concrete Inspection Work
This checklist help you in doing post concrete inspection work.
Checklist of Post Concrete Inspection Work consist of following checkpoints;
- Grade of Concrete - M15 / M20 / M25 / M30 / M35
- Finishing / Corners
- Shrinkage / Cracks observed
- Satisfactory Curing
- Honeycombing Observed after de-shuttering
- Formwork line / Level after pouring
- Steel Exposure on surface
- Hacking if required
- Concrete Strength 7 Day
- Concrete Strength 28 Day
- Proper de-shuttering
- Bottom level of beam more than 5.0 meter length
- Bulging of concrete surface
- slab top R.L.
