RCC Column Work
This checklist helps you in doing checking of RCC columns, Reinforcement and shuttering work checking.
RCC Column work checklist consist of following points;
Reinforcement
Sample checklist is attached in this post.
Reinforcement
- Column main bars are as per drawing
- All Links spacing as per drawing
- All rings provided with 135o bend inside (confinement)
- Covers provided as per drawing
- Joggles with correct slope (Max 1in 6) with extra stirrup
- Master ring provided above top level of concrete (app.1meter)
- Overlap provided for column bars in central zone
- Staggering of bars done at overlapping
- Approved formwork drawings available on site.
- Size and diagonals of column as per drawing.
- Plumb, Right angle and alignment checked
- Gap sealing done at starter level and for all sides
- Spacing of horizontal runners(chavi) as per drawing.
- Spacing of vertical Wailers(Patti) as per drawing.
- Horizontal wailers flush with vertical runners
- Tie rod provided as per drawing
- Sufficient cross bracing provided to support the column
- Shikanja spacing is as per drawing
- Independent platform erected for casting
- Top level of concrete marked from inside
