Work Checklist - Slab and Beam Reinforcement Works
This checklist helps you in checking reinforcement of slab and beam.
  • Checklist of Slab and Beam Reinforcement Works consist of following checkpoints in it;
  • Beam reinforcement checked as per Drawing i.e.- numbers and size of main bars, stirrups.
  • Slab Reinforcement checked as per Drawing i.e.- Spacing and size of bars.
  • Approved bar bending schedule available
  • Straightening and alignment of the steel bars satisfactory .
  • L-Bend provided at the discontinuous ends of slab
  • Lap length as per RCC Drawing or minimum 30D
  • Lap position is as per Drawing
  • Rings provided as per Drawing. At column beam junction .
  • Horizontal rings(earthquake rings ) provided in beam near the column .
  • Column reduced from appropriate direction as per drawing.
  • Reduction rings provided at column reduction position
  • Bent up bar position checked as per drawing
  • Chairs sufficient and strong to avoid bending of top reinforcement
  • Min. 3 rings provided above slab level for column reinforcement
  • Dowels kept for adjoining work (IF ANY)
  • Provision made for the elevation treatment if any .
  • Covers provided as specified for the beams and slab
  • All rings provided with 135o bend inside (confinement) .
  • Sleeves provided at appropriate locations.
  • Pin bar of min. 20 dia are provided to avoid touching of main bars
sample checklist is attached herewith.
  • C4M Slab and Beam Reinforcement Works.docx
Reactions: MANSURI ARFAT
