Soling Works
This checklist provides a checkpoints to ensure during the soling work.
Checklist for soling consist of following points;
- Quality of the available stone acceptable
- Compaction of the sub base material done and checked
- Level of sub base checked
- Thickness of soling checked
- Small "Kapchi" stone filled in gaps of laid stone soling
- Murum spread over the top of soling,watered and compacted
- Top level of the soling checked
