Can we use M-sand for plastering?
shafi12344
Apprentice
Specification ASTM C 142
Sieve Size (mm)
9.50
4.75
2.36
1.18
0.600
0.300
0.150
0.075​
Natural Sand
100
95 - 100
70 - 100
40 - 75
10 -35
2 -15
0 - 5​
Manufactured Sand
100
95 -100
70 - 100
40 - 75
20 - 40
10 - 25
0 - 10​
If the material not comply this limits can use ASTM C270-04
Manufactured Sand with the granule thickness of 0 - 2.36 mm is suitable for all kinds of plastering requirements and is used across all segments such as Independent Houses, Apartments and other Residential & Commercial Projects. Plastering sand does not require to be filtered again at the construction site and can be used directly to prepare the mortar which saves labor, time and money.
Direct use of M-(manufactured) sand is little costlier. Hence we use blending with Crushed Sand. In Pune we are using it. However it needs to blend with crushed +manufactured sand in certain proportion, to obtain required sieve analysis as per IS code. And also need to add Shrinkage proof additives. You may also add Fly ash as additional blending.
