Almost all woods are sold in rate as per its density in Kg per cubic feet only.
To calculate the cubic feet of wood, you need to have its dimension with you in feets and doing calculations of Length x Breadth / Width x Height will give you cubic feet.
Higher the density the wood with moisture level not more than as specified, is considered as excellent.
