CAN ANYONE PLS SEND RATE ANALYSIS EXCEL SHEET FORMAT FOR ALL TYPE OF WORK............
Thank you !!!Please find attached a SPREADSHEET for rate analysis of CPWD, Delhi. You have to have to put the values of existing basic rates in your locality. This will fulfill your needs. You can get pdf documents in the CPWD website
Sir it is password protected can you please provide me the passwordPlease find attached a SPREADSHEET for rate analysis of CPWD, Delhi. You have to have to put the values of existing basic rates in your locality. This will fulfill your needs. You can get pdf documents in the CPWD website
Sir, can you please unlock basic rate tab ?Please find attached a SPREADSHEET for rate analysis of CPWD, Delhi. You have to have to put the values of existing basic rates in your locality. This will fulfill your needs. You can get pdf documents in the CPWD website
Can you tell the password so that i can it use it as our working and thanksPlease find attached a SPREADSHEET for rate analysis of CPWD, Delhi. You have to have to put the values of existing basic rates in your locality. This will fulfill your needs. You can get pdf documents in the CPWD website
Hello Pls give the PasswordPlease find attached a SPREADSHEET for rate analysis of CPWD, Delhi. You have to have to put the values of existing basic rates in your locality. This will fulfill your needs. You can get pdf documents in the CPWD website
please provide passwordSir it is password protected can you please provide me the password
please provide passwordPlease find attached a SPREADSHEET for rate analysis of CPWD, Delhi. You have to have to put the values of existing basic rates in your locality. This will fulfill your needs. You can get pdf documents in the CPWD website
Can you please share the password?Please find attached a SPREADSHEET for rate analysis of CPWD, Delhi. You have to have to put the values of existing basic rates in your locality. This will fulfill your needs. You can get pdf documents in the CPWD website
The sheet is password protected, can you share the password to make it user friendly?Please find attached a SPREADSHEET for rate analysis of CPWD, Delhi. You have to have to put the values of existing basic rates in your locality. This will fulfill your needs. You can get pdf documents in the CPWD website
